BobsYourUncle
Jul 08, 2013Nomad
You cannot remove the "covering" on the paneling. It is bonded from the factory and impossible to remove without total destruction of it.
Best to find a new panel that is similar in color and texture or, as mentioned, find a contrasting color and use it as an accent.
Most of the time the paneling is glued and stapled to the studs. It is a bear to get off and you will wind up destroying the panel trying to remove it.
Been there done that.
Looking for advice before your next adventure? Look no further.25,211 PostsLatest Activity: Aug 30, 2026
