12th_Man_Fan's avatar
12th_Man_Fan
Replace frameless windows
I broke a window in my rv and it is the frame less type. I have a new one on the way, just wondering if any of you have replaced one before.
Anything I need to watch out for?
I have not been able to find any You Tube video's or other info. on line.
  • I just did one yesterday...they're actually easier than the older windows that used putty to seal. The newer frame less flush mounts use a rubber gasket to seal. Just make sure you have a helper especially if it's a bigger window.
  • I unfortunately left my bedroom slide-out frameless window open (in pushed out position) and then took off on a trip. Stopped about 2 hours later and realized the window was missing. Had to duct tape cardboard into the open space for the rest of our trip. I called Cedar Creek and they replaced the window for free! Not sure why they did that, but we'd owned the Silverback for just 4 months when this happened. Plus I told them I'd come down and pick it up since we live about 50 miles from the factory.
    The surprising thing is that the frameless window comes in a frame. I couldn't just replace the glass portion, I had to replace the whole thing which meant I had to take the old frame out first. Once I got started on the project it wasn't all that difficult. I did use a fair amount of caulking around the window frame to keep water out. It's been in for over a year now and no problem with leaking.
  • Our Jayco has them. Two benefits: aesthetics and keeps UV off the rubber window seals.
    The disadvantages appear to be more: can't open them all the way, difficult to repair the casement mechanism for starters.
  • Sorry I do not. Can anyone tell me the benefits for the consumer regarding "frameless windows"?
