Chum_lee
Jan 16, 2023Explorer
SlowBro wrote:
Our older RV (2005 Fleetwood 25QB) fridge (Dometic RM2652) died, and I'm wondering if there's any issues replacing it with an RM2620? It is not listed as a replacement model in but as far as I can see the only difference is it's slightly smaller, and I could just shim and bolt it into place as securely as possible.
I wouldn't say it's "slightly smaller," . . . . . I would say it's considerably smaller! (about 2 cubic feet smaller) If that's OK with you, then, IMO, it's just a matter of some minor cabinetry work (filler slats/panels) and possibly some plumbing work if the propane connection ends up in a slightly different location because of how you choose to mount the new unit. If the 2620 has a condensate drain, make sure there is adequate slope/location to drain the the exterior.
Think of the information in the chart as "for direct replacements" which the RM2620 is not. I believe the RM2652 still has parts available direct from Dometic, and in the aftermarket if you go that route. At least it did was when I replaced my entire unit (RM2652) in 2015. They have gone up quite a bit in price since then. If I remember, I paid about $1,350 installed for a new RM2652 then. I've recently seen refurbished units on Ebay for about $1,000. (add hefty shipping fee)
Chum lee
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
