wa8yxm
Jan 16, 2023Explorer III
Ok when replacing the entire fridge there are basically two considerationss
SIZE.. Smaller you can indeed shim or reframe. but the job may be more involved than you think due to the way the cooling unit works.
RV or "Residential" or .. Special
RV fridges are designed to work off either Electric or propane.. On propane they do eat a small amount of electrical power but.... Mostly propane. So they can go a LONG time on batteries alone.
Residential Do not eat propane. ever.. So you can cap off that line or trace it back to the manafold and plug it off. BUT they do eat ELECTRICITY If you plan to run off battery power you will need some upgrades... and in inverter.
There is a new "Special" type. I call it "Danfoss" after one of the companies that makes this class of compressor.. If someone knows the proper class name. PLEASE let me know.
These are all electric... around 50 watts. (Door closed) Both Norcold and Dometic at one time made them in RV-Sizes.. I have a chest freezer in this class (Small job) used to have one slightly larger lasted 18 years. THey too last quite a while on battery and work very very well. especially under adverse conditions (High/Low ambient temps) (Same as residential in that respect).
And finally: As someone said why not replace just the cooling unit... Thats how I fixed mine..
Some information on RV fridges The box is basically styrafoam. There is a metal frame on which the door hangs.. There are Electronics that sense temp and control it (Scattered about both inside and out)
And the cooling unit. this bolts on the back of the box.. No part of it is inside the box (The fins are not part of the cooling unit) you pull the thing out dissassemble. reassemble with new cooling unit and put it back.
NOTE: I'm making it sound a bit easier as you will reuse the burner and electric heater. the control computer and other stuff so there is quite a bit to disassembly and re-assembly but it can be done "on the bench" as it were.
Technician and I did mine in about 2-3 hours and then since I was last customer of the day we took each other to supper (She drove I paid) got back and it was already cold.. Total for two jobs was (That and a new floor in the slide out) was 2300.00 give or take pocket change. The floor took longer. LOT longer.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
