enblethen
Oct 30, 2019Nomad
OP: what is wrong with your existing solenoid(gas valve)?
They are a very simple device. 12 volts DC is supplied to the two coils, which opens the device.
One issue that I have run into is a poor ground. It is connected to the mounting bracket right where the water from drain plug hits. This causes corrosion.
The orifice is mounted directly to the solenoid. It needs to be cleaned occasionally.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Apr 15, 2020
