willald
Nov 01, 2022Explorer II
rk911 wrote:
being pressured or pushed into something, especially a home or RV, is a bad situation. I'd walk away. beyond that an "instant" water heater is something I would never consider for an RV as it takes away the option to heat your water with propane using a dual-fuel water heater.
The problem is, a lot of new RVs are now coming with the instant hot water, so you don't get a choice in the matter. That is, unless you're willing to wait forever for them to custom build you a unit without such. That, or stick with used. Guess you might convince the RV dealer to swap it to conventional water tank as part of the deal, but that might be a tough negotiating point.
Our Newmar (see signature), the next year model after mine, Newmar started putting the instant hot water unit in, basically forcing it on you like original poster indicated. Glad I bought mine when I did, cause like many here, I don't want instant hot.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 19, 2026
