PA12DRVR
Nov 02, 2022Explorer
Bobbo wrote:PA12DRVR wrote:
No dog in the hunt but what is the beef with an instant vs. traditional water heater?
With the instant hot you have to maintain a certain volume of water flow or else it won't activate. If you take Navy showers, no hot water. If you trickle a little hot water while doing dishes, no hot water. Insufficient water flow in both of those scenarios.
Got it....I use a instant at the cabin (not an RV) that is ideal for that mission ....propane fueled, doesn't require power (just water pressure), ignites off the flow, etc....but out at the cabin, neither water volume (500 gallon catchment) nor flow rate / pressure are otherwise restricted.
Thanks for the info.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 19, 2026
