bigred1cav
Feb 07, 2014Explorer
Thank you. Are the chairs bolted to a threaded location in the deck of the MH? Or are they attached through to the underside by bolt and nut?
the bear II wrote:
You can add a larger (than the metal ring) round wooden disk to the bottom of any recliner/rocker this will make it more stable for travel but still allows you to move it easily if needed.
OR You can match any existing mounts through the wooden disk. Just attach the metal ring to the wooden disk and then drill holes in the wood for the exisitng mounts.
Looking for advice before your next adventure? Look no further.25,191 PostsLatest Activity: Apr 04, 2026
