CND_SuperCrew
Apr 20, 2014Explorer
dodge guy wrote:
The tires will require a few hundred miles to break them in (heat cycle). this makes the tires less squirmy! look up new tire squirm or heat cycle and you`ll see this is common with many new tires.
+1
As long as they are load E and properly inflated- 80psi while towing, you're fine. As above, it just takes some time to break in. Much more noticeable while towing...
Looking for advice before your next adventure? Look no further.25,174 PostsLatest Activity: Nov 02, 2025
