fj12ryder
Feb 05, 2015Explorer III
The used Dodge Cummins I bought had a K&N filter installed. When I pulled it to clean it I discovered that deep in the pleats was dirt and crud that I couldn't safely remove. It would have destroyed the filter. I put in a Wix and that is what I now use. I use K&N filters in all my bikes and like them very much.
However I feel that using a K&N in a large diesel is not a good idea, unless you clean them thoroughly and frequently. Also you have to be careful not to over oil the pleats as that can cause some problems with the MAP/F sensor on some trucks. I think if you use one you would need to clean it thoroughly every 5,000 miles or so. JMO of course.
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: Dec 07, 2025
