So it seems to me that what you're complaining about is the noise the A/C makes yet you're blaming the thermostat. :R Regardless of what thermo you're using the A/C is going to be noisy when the fan is running so if your actual complaint is you have to continuously adjust the TV volume I'd ask why you wouldn't just set the A/C fan so it runs all the time. :h Nonetheless, if you're still convinced replacing your Coleman thermo will solve your problem you'd first want to identify just which model you have as there are at least 2 dozen different Coleman branded thermos currently available and you'd obviously want something that would be compatible with the system you have.
