SoundGuy wrote:
TNGW1500SE wrote:
Coleman Mach 8330-3362
I do run the fan all the time
Earlier you said - "The A/C cycles on and off to often for my taste. The roof A/C unit is close to bedroom and when it kicks on, I have to increase the TV volume. Then when it goes off again, I have to lower it. I spend the evening with my finger on the volume control."
Since the vast majority of A/C noise is caused by the fan and not the compressor these would seem to be contradictory statements because if the fan is on all the time the noise would be fairly consistent and there should be no need to constantly change the television volume. No? :h
What I hear is the compressor and fan in the roof unit.
