fickman's avatar
fickman
Replacement tire questions: PUP
We just bought the PUP in my signature from my FIL. It sill has the original tires on it (Loadstar STR185/80D13). We're planning an ambitious adventure of just under 1,200 miles round trip in a few weeks.
I'll have my BIL (he's a lead mechanic at Firestone) look at the tires, but I'm leaning to replacing them even if they pass his inspection. From reading around and searching through this forum, I've come to a few questions:
I know this is an endless debate, but what would you recommend as the best tire to keep the same wheels?
- Better brand ST tires with 65-75 mph speed rating?
- P-rated tires?
- LT tires?
If I go with LT, should I get the lowest load rating that is equal to or one step higher than the current tires? (Thinking I don't want to rattle the thing apart by going too stiff.)
IIRC, I should reduce the load and speed rating of P-metric tires by 10% or 15% if used on a trailer. Is this correct?
Thanks. DW is on her way to the shop now to get another issue looked at, so any input / experience / advice is definitely appreciated.
  • fickman wrote:
    ....- Better brand ST tires with 65-75 mph speed rating?
    - P-rated tires?
    - LT tires?...
    All ST tires are rated for 65 mph max.
    P tires have softer sidewalls but can be used on a single axle, I would never recommend for a tandem axle.
    LT tires are probably overkill
    I bought Greenball tires at Sam's Club last year. So far so good.
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: Dec 02, 2025
