ewarnerusa
Aug 14, 2017Nomad
OP Update
While starting with asking the RV dealer for suggestions may seem obvious, I had avoided doing that expecting that I would need to drop off the trailer for them to repair and pay a fortune in parts in labor. Turns out they have coroplast available from a 70" roll that you can buy by the foot to fix it myself. Perfect! Except they are low on stock and I'll have to wait a week or so for them to get more. The sheet that came off is 70" wide that spans the distance between the trailer frame rails. Must be an industry standard. I believe they said $7/ft which would make it only slightly more expensive for the replacement parts than the ~$22 per 4'x8' sheet from Home Depot. Plus I'd much rather have it be a single continuous sheet going back on than multiple sheets. I'd be afraid of air getting between the sheets and ripping the whole setup off again.
Looking for advice before your next adventure? Look no further.25,211 PostsLatest Activity: Sep 01, 2026
