NRALIFR
Jun 09, 2020Explorer
Grit dog wrote:
"Otherwise get a 500 watt inverter to run the 120v element on battery power."
But doesn't this suck even more power from the batteries than DC mode alone?
I'm not tracking here.
Yes, you’re tracking just fine.
The AC element is typically rated at a much higher BTU than the DC element. As an example, on my fridge running in AC mode from the inverter, the Trimetric panel shows about 27 amps coming from the camper battery. Even with my 25 amp DC-DC charger, that leaves me with about a 2 amp deficit. If I set the fridge thermostat at too high a setting so that the cooling unit runs 100% of the time, the camper battery slowly loses ground over the span of a days drive.
If the fridge is running in DC mode, the Trimetric panel shows about 19 amps from the camper battery, and the 25 amp DC-DC charger is more than able to keep up with the load, even if the fridge thermostat is on its coldest setting causing it to run 100%. But, since the DC element is a lower BTU rating, it’s not really able to cool the fridge as much as the AC element anyway. It works well enough to use it in >100* temps though. Since the voltage to the DC element is being maintained at about 14 volts, it performs noticeably better than before.
The voltage used to start out just under 13 volts with a fully charged battery, and get worse as the day wore on, making the DC element put out less and less BTU’s. In really hot weather, the fridge temps would get high enough that I would worry about the safety of some of our food.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 10, 2026
