JIMNLIN
Feb 29, 2016Explorer III
Moving from a 14" trailer wheel/tire to a 15" tire/wheel is one of the best upgrades you can do with a trailer if your trailer has room in the wheel wells for the upgrade.
The best part of the move it gets you away from a ST tire.
Depending on room in the wheel well and proper wheel pressure/wheel width requirements the Goodyear Wrangler HT in a LT235/75-15 C (50 psi) at 1980 lb capacity. Most LT tire makers carry this size.
And a Wrangler HT in a LT215/75-15 D (65 psi) at 2090 lbs capacity.
Maxxis LT U-168 is a commercial grade tire with several 15" sizes and have became popular with all types of trailer owners.
Vanco 2 from Continental another popular tire for trailer users has several 15" sizes and load capacities.
I see the Yokohama RY215 in a 700R 15 D at 2040 lbs capacity is popular on some of the other RV websites.
Goodyear Cargo G26 2249 lb capacity in a 225/70R 15 C 65 psi load range D for trucks/vans and trailers. The G26 also comes in a 195/70R 15 D load range.
Do your home work on the numbers.
Now if your wanting to stick with the 14" OEM wheel check out the Kumho 857 commercial class tires.
Looking for advice before your next adventure? Look no further.25,195 PostsLatest Activity: May 02, 2026
