tfdcc's avatar
tfdcc
Res Frig
We just got our new Solitude 369 fifth wheel with a residential frig. I keep it at the house and plugged in all the time. Is it best to let the frig run all the time or try to turn it off when it its not needed? What is the best way to keep it from running all the time? Thanks for any help. Chris
  • rjxj wrote:
    Mine is on solar so I just leave it on
    Mine operates on solar, too. I keep it off and empty when not being used. I figure battery and inverter longevity will be increased because of that choice.
    It sure would be nice to have the ketchup, mustard, and drinks with all the rest in the box usable, though. :C
  • I have found keeping mine running all the time works best. We keep a bunch of bottled water in there so its not completely empty. If you want to turn it off, you can do so by raising the temperature setting until it turns off.
    Not sure if this has anything to do with it but I turned mine off over the winter from December until late March. Then on that first trip, the compressor started going bad. It had to be replaced but fortunately, under warranty. Now mine runs 24/7/365 just like the unit in our house.
    If you decide to leave it running, maybe raise the temp setting just a little so it doesn't run as much.
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 11, 2026
