Sort By
- mr__edExplorer
B.O. Plenty wrote:
The nice thing about a residential fridge is they only take a couple of hours to cool down.
B.O.
Another nice thing about a residential fridge is that it isn't as fussy about leveling like an absorption unit is. - MFLNomad III'm joking JR...Jerry (me) does not block anyone, in fact I enjoy reading almost everyone's posts, especially Grit's!
- JRscoobyExplorer II
MFL wrote:
JRscooby wrote:
I must be blocked so my replies don't get thru
You guessed it JR!! Here is a member blocking you, as you type!
"blocking members is a blessing" Lol
Jerry
I understand that Jerry will not see this. I have to wonder though. If somebody is looking for a solution to a problem why would you want to limit who could give ideas? Even if it is a bad idea, thinking about why it is bad might give you a better one.
If the only time OP is worried about not having enough battery power is to pre-cool the fridge does it make sense to spend for, and haul around more battery? I bet most people on this site have iced down a cooler full of food/drinks. A bucket of ice in fridge overnight, then pack with cold food sounds like not much more hassle than turning it on the night before. - MFLNomad II
Jerry - StirCrazyModerator
willald wrote:
goducks10 wrote:
I would suggest upgrading your charger to a Progressive Dynamics that has the option to bulk charge anytime. Even if your batteries drop down 30-40% a standard WFCO won't bulk at more than 13.6-8. You waste a lot of time trying to quick charge at 13.6.
Not sure who this was directed to, but in my case, putting in a PD converter would be not only a huge down grade and not very smart, it would also be nearly impossible without redoing much of the electrical system.
Our RV has the Xantrex Freedom XC 2000 Inverter/charger unit.
not sure I would agree with you on that one. Xantrex is a upgrade from WFCO, but I wouldnt say a upgrad over PD. but since you chose to go with a inverter/charger all on one unit I wouldnt change if I were you either. PD would be a quality upgrade on the actual parts but like you said not worth it in your case. - JRscoobyExplorer III must be blocked so my replies don't get thru
- austinjennaExplorer
Doubt you'll get a new camper with a residential fridge and 1 battery, but in general, OE power and a residential compressor fridge is still a poor combination.
I know you think you have just a specific short term situation that you will need to run off of an inverter, but it's quite possible that you're not considering all scenarios. You only travel an hour or 2? Charging while traveling? Run onboard genny or install a heavy duty dc dc charger?
I'm not even sure what you are talking about. If you read my initial post I was wondering how long it would run on 1 battery because currently with my gas/electric fridge I start it up the night before in the storage lot then the next morning when I bring it home its cold, then load cold items into it and done.
I was wondering if I could do the same thing with a residential fridge and it seems from the responses the answer is no unless I add more batteries.
My storage lot is 2 miles from my house, so picking it up, turning on the fridge, it will not cool down in the 5 minute ride home to start stocking it up.
I know the batteries charge while driving. - Grit_dogNavigator
time2roll wrote:
I calculated 2x 30# cylinders should last about 45 days (seems short). With portable cylinders I don't have to break camp to run out for a refill. Anyway as a part timer I can't see staying in one spot for much over a week.
My last fill was $28 for 30# would compare to $200 to fill with gasoline.
Yes, that's short. LP fridge doesn't even use that much.
Fridge in our AF TC, 1 30lb bottle, month long trip, plugged in for about 5 days at one spot and normal daily run of the genny to charge batteries a couple hours, ran the fridge, hot water for a family of 4 and occasional stove use and was still very heavy at the end of that month.
They really do sip propane. - Grit_dogNavigator
willald wrote:
Grit dog wrote:
...Bottom line, resi fridge unless the camper is parked at a power source 99% of the time is an effort in futility...and warm beer and soggy freezer!
As one thats owned a total of 5 RVs over the course of last 22 years, 4 of which had absorption style frigs, the last of which has a residential refrigerator.....I have to respectfully disagree with this.
On the contrary, a residential fridge, when set up correctly with the right battery bank, an appropriate inverter to run it, and a generator to recharge when needed....Works very, very well for someone not planning to be near electrical hookups very much (boondocking).
As noted previously, I am able to run the frig up to 2 days without electrical hookup, off just batteries without ever cranking up the generator or burning any fuel. Run the generator for a few hours each day, I can run indefinitely, as long as the 80 gallon fuel tank holds up.
And, when I do finally need to refuel, I just need to get gasoline, not LP gas that can be more difficult to find. With an 80 gallon fuel tank, and the generator only using 1/2 gallon per hour maximum when running full power....I could camp for almost 2 months before we would need to break camp and refuel at all. I doubt that any RV with the older absorption style frig running on LP gas could go that long without refueling.
That doesn't sound to me like 'an effort in futility'. Sounds to me more like a very good setup for boondocking. I prefer this setup muuuch better over the previous RVs I had with the older absorption style refrigerator.
Weird, I think we agree, but it's probably more fun to just clip a short portion of what I wrote, to have an excuse for a nice story...
I actually said something very similar to your response, just not in the portion you responded to.
And each end user has different uses, needs and goals.
Me being the occasional weekend warrior, 50/50ish between having hookups or not, the additional time and expense to have a mack daddy onboard power setup is not warranted. Whereas, if you use your RV much more frequently, and have the want or need for a large battery bank, big inverter, multiple means of charging, etc, it is the right way to go for you and your use.
Looking for advice before your next adventure? Look no further.25,126 PostsLatest Activity: Apr 18, 2025
