westend
Jul 26, 2016Explorer
thirtydaZe wrote:I'm not really clear on the sequence of connection events but if the fridge is only tripping on inverter supplied power, the first suspect would be an under-voltage situation causing the inverter to trip. If you later came back and reset the inverter and the battery had a chance to charge, the same sequence may repeat.
Well on a side note i disconnected the rv from shore power, turned the inverter off and disconnected the battery, then plugged everything back in. Right now it appears the fridge is back up and running.
Assuming it cools to regular aperating temp without issue, whats causing these problems? At the beginning of the season, our first trip out, the fridge wouldnt even turn on after being in storage. I believe i had to unplug everything as i just did. Seems to be a reset?
Have you measured the battery voltage when this fridge event occurs?
What do you have for batteries and what inverter?
Looking for advice before your next adventure? Look no further.25,202 PostsLatest Activity: Jul 21, 2026
