riven1950's avatar
riven1950
restoring gel coat gloss ...small spot
We somehow acquired a small scrape on the side of the TT. Not very big, like 3-4 inches long. something scraped the side and left a mark. There is no dent or physical damage.
Problem is in getting the scrape off the surface the shine of the spot was lost so it is still noticiable as a dull spot surrounded by a high gloss elsewhere.
So what can I use to renew the gloss in the now dull area? The spot is maybe 2-3 inches in diameter, actually 2 spots about the same size.
The TT is a Apex with the Adzel walls, 2017 so it really shines except the spots.
Would multiple applications of a good paste wax do it or what do you suggest?
Thanks
  • Differing cuts of compound with a buffer. I'd start with a fine cut and see how it does.
    If you are not familiar with using a buffer a local body shop or detailer could probably make fast work of it. Buffers can cause more harm then good if not used properly.
Looking for advice before your next adventure? Look no further.25,173 PostsLatest Activity: Oct 26, 2025
