joeshmoe
May 09, 2017Explorer III
Gel Gloss
Where do I find this stuff? I keep seeing it mentioned, so I figure I'll give it a try. Home Depot, Lowes etc.? Does it come in large or small sizes.
Thanks.
Thanks.
Grit dog wrote:
It's not a polymer, says carnuba wax and cleaner (abraisive).
Grit dog wrote:With all of the experience you listed, I question anyone could provide any technical related information you can't read off the container. Like you, I have tried too many waxes and cleaners to list, and will still try different one on occasion. I don't sell any of it, but my "draw" is pretty simple. I find it easy to use, reasonably priced, available at most hardware and RV supply stores.
What's the draw to this stuff? I'm all ears, always looking for a better/lazier way to keep everything shiny and beading water!
Reddog1 wrote:The Wolf Creek is the typical smooth fiberglass. Should be fairly easy to "swab" on and off. Not looking for a perfect solution, just something easier. Plus, I'm tired of paying someone else to detail it. Thanks for tips.joeshmoe wrote:That is how I apply it on my molded Fiberglas Bigfoot. I do it in the shade.
Picked up 16 oz bottle at Lowes.
Wayne, so you apply with foam mop and remove with cloth attached to mop?
Apply the wax, and wait for it to haze. I then use a towel on the mop to wipe off the haze. I think using a towel to remove the haze is the most important.
I don't think if you wipe before the haze, is a big deal, you will just have to work a little harder. If you allow direct sun to cook the wax before you wipe it, you can use additional wax as a solvent. You put the wax on and immediately wipe it off.
It could be argued that applying by hand and wiping the haze off by hand while standing on a ladder could insure the wax is in the nooks and crannies, but I find it too time consuming. TCs with metal embossed skins may require this method. I have a metal sided fifth wheel. On it I use the towel, and a soft brush.
Reddog1 wrote:
You do not need a gallon. I buy it from Home Depot. At the store where I shop, it is not in the wax department. I think it was in the bath tub area.
A word of caution, don't use it in the direct sun. You will really have to work to get it off. If it does dry hard, just give the area another wet coat then buff off.
