Gjac's avatar
Gjac
Explorer III
Sep 14, 2020
Reverse shoulder operation
Have any of you guys had this procedure, if so how did it turn out? How long was the recovery?
  • Gjac's avatar
    Gjac
    Explorer III
    BobsYourUncle wrote:
    Gjac wrote:
    Glad you are on the mend Bob. Do you know what he actually did to make the repair? I did not realize I torn mine completely off over a year ago that is why they shrunk. Apparently other muscles get stronger and compensate somewhat so I was still able to do pullups and any kind of pulling exercises. I just could not push anything over head or any other pushing exercises. Then about a month age I fell off my bike in soft sand and that tore the bicep tendon and pulled it out of joint when I put my arm down to break the fall. I have an appointment next wed to review options. The reverse shoulder seems very extreme that is why I asked here hoping there may be another option.
    Thanks, yes I am on the mend for sure. I likely could have been further along, but I got lazy with my at home physio and exercise. I was actually very paranoid about re-tearing the muscles off again, so I was extremely careful not to overdo it.
    Doctor told me that he used something to basically "rivet" them back onto the bone. Not an actual rivet, but something similar in concept. He told me that with the attachment to the bone, it would bond itself naturally over time, which it has done.
    I was in a sling for 6 weeks with no use whatsoever of my shoulder. I could use my hand a bit at my side but no more.
    It sounds like your injury is similar to mine, so perhaps the extreme "reverse shoulder" procedure may not be needed. Obviously, I am not a doctor and I am only guessing at that. We are all different. But it sounds like yours was done in a similar fashion. If it is just a case of muscles/tendons being torn off the bone, then the arthroscopic procedure used on me may suit you. Arthroscopic is a small incision where they insert the tools to perform the repair, rather than cutting things wide open. It heals faster too. I have 3 small scars where he went in.
    My other muscles did indeed compensate, and I was still able to do a lot prior to surgery. I couldn't lift my arm over my head, but I could grab it with my left and drag it up there. Once above my head I could put a drill in my hand and use it, albeit with a lot of pain. Strange thing...
    I was still working out at the gym after the injury. I refused to accept I was hurt I guess. I was ok pushing / pulling down low, as long as I didn't try extending my arm. With the injury I could still dead lift 245 with a straight bar, 265 with a trap bar. Not bad considering I was 65 when I had things fixed.
    My muscles were badly atrophied before surgery, as they were torn right off and resting in the contracted position. But the doc was still able to stretch them out enough to reattach to the bone. I was nearly 4 years from the injury date to surgery, so they had lots of time to just sit there doing nothing.
    I agree with the things Kevin is saying here too, sounds like he is educated in this problem too.
    You are only a few years older than I am, you said you are active, so am I. I would try for the reattachment process before getting radical about it.
    Recovery? Well, I have to admit, after surgery I had a dickens of a time. There was no comfort to be found in bed. As soon as I laid down, the aching set in. And it was miserable. Lots of pillows, sleep upright, try a recliner chair, I did it all. I took the meds they gave me once, only once. Opioids, and they put me into a stoned stupor. I did use Advil for the first couple weeks, then decided to tough it out. Drug free body, and I like it that way. Yes I suffered a lot at first. However, after a couple months passed I was able to sleep again with less discomfort. It's a process, you gotta go through some ugly times for the first while. But it does pass.
    I am now pain free. My shoulder no longer sounds like a bowl of rice crispies when I move it. I am now glad I had it done, wasn't sure at first. The lack of living in pain makes it all worthwhile. I imagine I will be another while before I'm back to normal. I could exercise more..
    Yes Bob it seems like a similar injury. The only think different is my Dr said two of the tendon shrunk and could not be pulled back to the original position without the use of a cadaver skin to use as a filler material. The rivets you talked about were probably Ti moly bolts I already have 4 in each shoulder. The original surgeon said he would try to do it arthroscopically but I ended up with 4 in long scars. I guess the MRI helps but they can't really see how bad the damage is until they open you up. I have just been praying that the tendons can be repaired without going to this radical surgery.
  • Best of luck to you, and yes, let's pray it can be fixed with minimal effort.
    Do keep us posted.
  • I have no personal experience but my Bro who slightly older had the opration about a year ago. He is back at work as a contract management inspector for almost 7 months. Sore after splitting firwood, not pain, only about90% range of motion. The stupid s@#t is 80 and went back to work. Should have taken the retirement that was recommended.
  • Gjac's avatar
    Gjac
    Explorer III
    Do keep us posted.
    I saw the MRI and got the Dr's report this week. Two of the rotator ligament's are torn completely. The top one is contracted 2.5 ins so it cannot be stretched back and reattached. Apparently two were old tears more than a year old probably several years old. I did not realize it at the time but each time I used my arm more damage was being done. Bicep mussel is torn and out of position. He said I had a strong deltoid mussel so I can still lift my arm. He recommended still going back to the gym otherwise mussel atrophy would get worse. Just no lifting overhead and no adduction or abduction exercises then wait until the pain gets worse and get the reverse shoulder. Hopefully it gets better. Moral of the story is if you ever have diverticulitis and take Cipro to heal the infection it softens your ligaments, be carful what you lift.
  • Interesting analysis of the contracted ligaments.
    My injury was several years old when they did the surgery and they had been contracted a long time. They managed to re-attach them all. I was lucky I suppose.
    I guess we are all different, and our surgeons are too.
    Mine is improving every week and I am now trying to force more movement. I didn't do it at first even though they told me to. I was fearful of tearing the shoulder apart again.
    It is so nice to have the pain almost all gone, just the occasional twang if I do something. I can live with the limited mobility, but I may get it all back.
  • Gjac's avatar
    Gjac
    Explorer III
    Bob do you remember how much the ligaments were retracted? The Super Spinaus(one at the top) was retracted 2.5 ins. It was already repaired one in 2003 with 4 molly bolts. Did the have to use a spacer from a cadaver to reattach it?
  • I don't think my surgeon shared with me how much they were retracted. If he did, I don't remember. I do recall talking about the possibility of being unable to pull them into place and he would only know once he got in there.
    I don't recall the names of the various parts in there, it is written down somewhere. I have a record of which ones were torn off. One was actually attached to the bicep, and it was torn off at least 20 years ago, but he fixed it. Amazing! I was able to function normally for years with bicep damage.
    It was after surgery that he informed me it was a total success. Mine was the first time I had this done, and I have been extremely physically active all my life, especially with my heavy lifting and such in my work. Perhaps that played a role, I don't know.
    No extra material was added to mine.
    I was supposed to have a follow up visit several months ago, but with covid, that never happened. Last follow up was a phone call. If I talk to him again, I will try to remember to ask. I am still not cleared to go back to work, but I am anyways. I gotta eat too...
Looking for advice before your next adventure? Look no further.25,101 PostsLatest Activity: Jan 14, 2025
