Gator81Burb's avatar
Gator81Burb
Reviewing results from CAT scale weigh in
Hello - and thanks up front for the help. I know this is long post with lots of questions. :-)
I just weighed TV and TT at CAT scales. I would like to share the numbers, get your take, and I have three questions.
Background:
- TV is 2003 2500 suburban with 8.1 L, autoride suspension, 3.73 rear end, and LT245/75R16 tires.
- TT is 30 foot with 9500 GVWR
- WDH is blue ox. I set hitch almost as "strong" meaning there us only 2-3 more links available.
- During weighing TT had empty tanks and usual stuff when we camp. TV had 1/2 tank of gas and usual stuff we take camping.
Weight measurements - TV only
Front axle 3640lbs
Rear axle 3540 lbs
Total 7180
TT and TV -
Front axle 3440 lbs
Rear axle 5280 lbs
TT axles 7500 lbs
Total 16220 lbs
Question 1 - internet shows curb weight of TV= 5796 lbs. Is that right? How can I be 1384 lbs over curb weight with 2 ppl and 1/2 a tank of gas?
Question 2 - what is the GCWR for my TV? I can't find that anywhere. I know towing capacity of TV is 10,400 lbs.
Question 3 - total weight on both TV axles with TT attached is 8720 lbs. GVWR of TV is 8600 lbs. Am I unsafe? My GAWR front is 4180 lbs and 5500 on rear axle. So I am not maxing out axle rating.
Question 4 - with TT attached front axle is 200 lbs lighter than without TT. I don't have many more links available on WDH. Do I need a different hitch?
Thanks so much and again I am sorry for the long post!!
  • Actually I think I just answered question #2. I found a "GM Trailering Guide.pdf" that states Gross Combination Weight Rating" for my TV with correct options is 17,000 lbs. So I am 780 lbs under GCWR
