Turtle_n_Peeps
May 24, 2017Explorer
OP, I would never do this and here is why:
Trucks are notoriously unbalanced. That is why you see people putting sand bags or heavy plates in their beds. It's to get a better weight bias. The closer you get to 50/50 the better a vehicle will handle the better is will brake............the better it will do everything.
The new trucks are better. That's why you see the engines of new trucks stuffed up under the dash. OEM is trying to get close to a 50/50 weight bias.
Also; when you panic brake all the energy (weight) will try to go to the front bumper of the TV. When this happens it will squash the front suspension of the TV. The back of the TV will unload and try to lift the tongue of the trailer. The higher the front of the trailer and tongue the more successful it will be. This is a bad thing. Your trailer will then try to jack knife. For the best handling TV and braking combo you need to have your trailer an inch or two lower in the front and have a 50/50 weight bias on your TV when loaded.
The goal is when under panic braking is to get the hitch to line up with the tongue of the trailer. Not lift the back of the TV or squash it. With this you will get the best handling and braking TV/trailer combo.
Looking for advice before your next adventure? Look no further.25,192 PostsLatest Activity: Apr 15, 2026
