Buster52's avatar
Buster52
Road Grade
I understand there is a book or program that tells you what the grade of a road is. Also is there one that will tell you what route that maybe to narrow or windy, So I know what routes to take.
  • leeper wrote:
    Vail pass on I-70, Colorado is a big dog!. 10 miles going up to 10,000 ft. elevation with no escape at 7%. The elevation effects engine power. Elevation and grade slows you down to a crawl.
    Big dogs are easy to handle - even without an EB - just gear down and take your time. (Towing 34' fifth). CTD never needed to "crawl" going up - with the exception of US-6 detour.
    Had already done "The Vail".........
    Traveling Westbound I-70, Loveland Pass, Eisenhower tunnel (11,158 ft) was having road work, with height restrictions.
    Detour to US-6.
    BTW - Grade for the tunnel approach is 6 or 7 percent, depending on approach side.
    Elevation -
    Took "old" US-6 *over* the Eisenhower tunnel (11,990 ft) - top of the Continental divide - then down the other side.
    US-6 *is* a crawl - due to winding, one lane each direction - with tractor-trailers and oversize loads.
    Didn't find any dog(s) with attitude (altitude?) in the "height fight" or the grade/s..;)
    Enjoyed the view at 12K feet of the Atlantic & Pacific sides.
    Would do it again - nothing to see inside the tunnel..;)
  • With an 8% grade you will rise (or fall) approximately 420 vertical feet per mile driven. I always figure it off of 5000 feet (easier for me and it is close enough) instead of 5280.
    200 vertical feet per mile = 4% grade
    300 vertical feet per mile = 6% grade
    400 vertical feet per mile = 8% grade
    500 vertical feet per mile = 10% grade
  • wanderingbob wrote:
    What the heck does grade mean anyway ? Say an eight percent grade , eight percent of what ?
    slope
  • From a level horizontal plane, zero reference, add 8% of 90 degrees up and you have a "8% grade". Actual grade is less than 6 degrees
  • What the heck does grade mean anyway ? Say an eight percent grade , eight percent of what ?
  • There is also a Trucker's Atlas which shows all the roads that truckers can travel. We figure if it is safe for a truck, then it is safe fir us. It is also available at truck stops and has low clearance info.
  • It's also available as an app in the Androide and Apple versions. It's the route I went which was lots more cost effective.
  • It's called "the mountain directory" and there are an east & west version .... Available at amazon or any truck stop.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 10, 2026
