- Parts for the Sterling are still listed. Main difference between Sterling and the Sterling all Terrain is the release mechanism. Main components are the same.
- HikerdogsExplorer
enblethen wrote:
pauldub:
Roadmaster would rebuild your bar for you. They have done my Stowmaster several times for free. As close to them as you are, I would have taken it to them for a day trip.
They like to look at their products to see how they are holding up and what changes need to be made.
The major difference is that the Stowmaster is still in the current lineup. The Sterling was replaced by the Sterling All Terrain in 2005. As such it's at least 12 years out of production and is considered an obsolete product. I would call Roadmaster to see if they will still rebuild the Sterling, and also ask about price. At some point they are likely to stop servicing them. - pauldub:
They like to look at their products to see how they are holding up and what changes need to be made. - j-dExplorer III looked at the roadmasterinc site, towbars, and put "repair" in the Search Box. One of the items was 910003-30 which showed as Repair Kit for Sterling and Sterling All-Terrain. All it seemed to be, was two "Locking Springs." From there it was two new pins for the springs, two clips to retain the new pins, and four rubber caps that appeared to be mostly decorative. I suppose they'd keep dirt out of the area where the springs live.
- pauldubExplorerI have a Sterling that is worn out, the legs are very sloppy and there is a lot of slack in the lockup of the leg extension. It's not the greatest design and has nowhere near the durability of the Stowaway towbar. Roadmaster wouldn't sell me the piece parts to rebuild the Sterling. They thought I should buy a new one so I did and I bought a Demco.
- HikerdogsExplorerOurs lasted about 10 years and 100,000 miles before it was destroyed when the Jeep we were pulling was rear ended. That was about 4 years ago. At the time Roadmaster said they were no longer going to support that model since it was replaced by the Sterling All Terrain in 2005. However there have been members that have sent theirs back to the company to be rebuilt since that time.
If your is getting stiff or weak I would call Roadmaster to see if they still have a rebuilding program. It seems they were doing the job for around $200.00 plus shipping one way. They provide the return shipping. If the unit is beyond repair they generally offer a substantial discount off a new one. - My Stowmaster is over 20 years old.
Have replaced nylon bushings and buttons.
Keep it cleaned and lubed, you will never have to replace it.
I have had mine checked by Roadmaster. If you are up around Portland, Roadmaster is in Vancouver. They will check it out and do standard mantainance for free.
Looking for advice before your next adventure? Look no further.25,211 PostsLatest Activity: Sep 01, 2026
