Harvard's avatar
Harvard
Roadmaster Telescopic Tow Bar vs Toad Tires Gotcha
I just had the opportunity to suggest to a fellow RVer that he should make sure is telescopic arms be fully extend and locked before he departs.
I learned the hard way, by wasting a couple of front tires on the toad, we run the risk of the departing toad front wheels turning full left or full right before it all settles down.
At first I thought my toad tire wear problem was about tight turning while accessing service stations.
  • dkreuzen wrote:
    I back up my Jeep to lock the tow bar then put it in neutral. That way I know it's locked and I can do it myself easily.
    I do the same thing but then when taking off in the MH I turn left and right a couple of times to make sure both sides are locked. Usually when I back the Jeep up only one side will lock unless I am perfectly straight.
    X2. The only difference is our Jeep goes in Park. It only takes a second. You're in the toad to set the shift lever and put the transfer case in neutral anyway.
  • I back up my Jeep to lock the tow bar then put it in neutral. That way I know it's locked and I can do it myself easily.
  • After I hook up I always turn left, then right, then left, then right again just to make sure. I can see the towbar lock in my rearview camera. If anyone was watching they would think I had too much to drink.
Looking for advice before your next adventure? Look no further.25,151 PostsLatest Activity: Jul 25, 2025
