Popester82 wrote:
What should I treat it with or is staining ok. And use 1/4 ". Correct. Thx again
A sanding sealer works great for minimal cost. From there the sky is the limit, with fiberglass or epoxy resins, but not necessary if you have stopped the leaks. Be aware that many of the sanding sealers are organic based (shellac)and will be susceptible to mold if the area is not kept dry ; don't ask me how I know that. With any plywood or luan , make sure to seal the edges well, this includes after making cuts as they will suck up moisture from the edges far faster than the sides.
