Bob_Vaughn
Dec 15, 2017Explorer
Mr Wizzard the compressor only runs for 2-3 minutes at a time then shuts off and the evaporator fan will run for a couple of seconds at a time for about 5 minutes then the compressor will come back on but for only 2-3 minutes. Thus when it is say 50 degrees outside the heat loss is as much as the heat gain thus it will never raise the inside temp. There are 4 sensors on this system and I think one in the plenum may be prematurely shutting the compressor off before the thermostat gets a chance to be satisfied. It is an electronic thermostat so it does not have an anticipator. If it had an anticipator I could adjust that but it does not. I do not think it has a high pressure cut out because if it did it would shut it off when it was in the A/C mode. I have asked Atwood for a wiring schematic but they say one does not exist. Which I think is BS.......A/C tech's would not be able to repair them with out one.....That may be why the repair place that installed it could not fix it.....
Looking for advice before your next adventure? Look no further.25,202 PostsLatest Activity: Jul 21, 2026
