Bob_Vaughn
Dec 19, 2017Explorer
BarneyS wrote:Go to the connector and tell me what color the 4 wires going into the connector and what color the 4 wires are coming out of the connector........Bob Vaughn wrote:Shal36 wrote:I am convinced that there is a design flaw and Atwood will not admit it .....they will not release a wiring schematic just a block diagram which does not show what color the wires are so it is useless to try to use that to trouble shoot. For instance it shows a connector with 4 attachment points but does not show what color the wires are going in an out of this connector....
The Atwood heater does not perform well. Fortunately, I bought the unit mainly for the AC portion. I found that the heater will not reach the temperature I want and will not keep it there, even if it’s not that cold outside.
I guess I am going to be the odd man out here. My Atwood 15000 btu works well in both air conditioning and heat pump modes. The fans do do some weird things on heat mode but it does warm up our 30ft trailer quite well and will hold the temp I set after a while.
Don't know if the following wiring diagram will help you or not. It does seem to show the wire colors.
Barney
Looking for advice before your next adventure? Look no further.25,202 PostsLatest Activity: Jul 21, 2026
