jondoexxxx's avatar
jondoexxxx
Roof Repair Project (Advice needed)
Hi,
I am a newbie, just bought an 88 Minnie Winnie with 75k miles and first thing I wanted to do was fix some issues with the metal roof.
I pulled off a cargo box that was installed as it seemed like it was going to leak and patched the holes with Heng's Alkyd Fibered Roof Coating - Elasto-White.
Next up I need to repair some areas where the seams on around the sides, vents, etc. is cracking and coming up.
I started with just a scraper, but found that the hard roofing material that was used before was put on top of some sort of caulking and wouldn't really chip off very well. I ended up using a heat gun to loosen the material and then was able to scrape most of the caulk and roofing material off.
What I am wondering is whether I should continue to scrape and then maybe sand down to the raw roof metal / siding? Or if I am good to just use the Roof Coat on top of the thin layer of caulking that remains? Should I apply a new bead of silicone or other rv caulking and then apply the roofing agent?
I am hesitant to get too much further down this rabbit hole, but also don't want to do a bad job.
Any advice would be greatly appreciated!
Looking for advice before your next adventure? Look no further.25,194 PostsLatest Activity: Apr 25, 2026
