ROOF REPAIR SEALANT WHICH ETERNABOND OR OTHER OPTIONS
We've been led to believe that Eternabond is likely the best option to seal all around our skylights, fans, antenna, air horns etc = basically everywhere there would likely be a leak from the roof to ...
Eternabond Roofseal is the one that will work with most of your roof through holes. If you have things to seal that need a tape that will bend or conform to any angle, Eternabond Webseal does a good job on that. Webseal needs to be painted, Roofseal does not.
Looking for advice before your next adventure? Look no further.25,210 PostsLatest Activity: Aug 30, 2026
