I will spare you hours and hours of details and ask this simple question. How do you tell if a fifth wheel roof is rotted? We suspect the wood on which the AC is mounted has rotted, resulting in wate...
AC sits on a gasket which is sandwiched between roof and AC - if gasket is loose or needs replacing water can enter the rig. Sometimes simply tightening the 4 bolts that hold the AC unit on the rig will compress the gasket eliminating the leak.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
