3_dog_nights
Jun 29, 2013Explorer
JaxDad wrote:
If the unit was used a lot in a c/g that had a well of its own, and was in an area where there's sulphur in the water, there will be a layer of sulphur-bearing silt in the bottom of the water heater.
Pull the drain plug and /or anode and use a strong stream from a garden hose directly in the tank hole. Bet a bunch of crud washes out.
Have had the problem a few times in the past, JaxDad's answer is the best solution I found. Backflush repeatadley till you smell sweet water. After that I've gotten in the habit of draining my water heater when I get home. Only take s a minute or two and no more problems. Just don't know what you are going to get in the water when traveling. That's why we drink bottled.
Looking for advice before your next adventure? Look no further.25,195 PostsLatest Activity: Apr 08, 2026
