jake2250's avatar
jake2250
routine maintenance
Spent the last three days removing dried out and cracked Dicore and silicone caulking from trailer seams.
Trailer is an '06 and two years ago I re did the roof seams with Eternabond!!
Great stuff!!! Thanks to the forums I learned about it.
I realize that it is my responsibility to maintain this,, but I was surprised at the wear on the caulk!!!
Sure am glad I took the time to do this as this will add years of enjoyment to my rving!!!
Word to the wise,, look at ALL caulking on your trailer,,even the vertical supports!! Mine were dried and cracked...
  • For one silicon cannot stick to silicon. If you must reseal you must remove. The Dicor type sealant for roof seams is a self leveling with means it will flow better into the cracks of the seams. You could also add more to the Dicor if needed without removing it.
    From an online article:
    'If you see a water leak in your RV’s rubber roof don’t make the mistake of trying to repair it yourself by using a silicone sealer.
    In our RV Service department the most frequent issue we see with incorrect caulk, is the application of silicone seal.
    Installing silicone seal is absolutely the WRONG WAY to caulk anything on the roof of an RV.
    Why not use silicone?
    Over time silicone tends to shrink and pull away, once it has pulled away, water can go right under the silicone and get trapped. Water trapped underneath the silicone can never dry out.
    Removing silicone seal without doing additional damage to the roofing material is nearly impossible.
    As a general rule the caulking that should be used for an RV roof is not available in a big box or hardware store.
    If you are going to repair a leak yourself we recommend the RV caulking be purchased from a qualified RV supply store to ensure you get the correct product for your RV."
  • mark5w wrote:
    ...and don't use silicone caulk on rv roof.
    Why?
    I ask because I have a friend who uses it on his roof. I said same to him and he asked me why.
  • Bobbo's avatar
    Bobbo
    Explorer III
    Or anywhere else on the RV!
  • I would also check all the 12 volt grounds where they attach to the metal frame usually. Most 12 volt problems are ground related. I routinely check all I can get to, especially any exposed to outside wx.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
