wa8yxm
Apr 14, 2014Explorer III
If the park has good power and you minimize other use I have run two 13.5KBTU A/Cs (Carrier Air V's) on 30 amps for like half an hour,, Monitored current draw and the units, which had JUST been cleaned, (This is the 2nd time I did it) were drawing exactly their rated consumption of 13.5 amps each (27 total) per the clamp on meter.. The first time I did it they were brand new and thus clean.
IF the park's power is a touch anemic (Many are) no joy doing this.
But one A/C and the fan on the other.. Should work be no tribble at all since the fan motor is at most 5 amps and likely closer to 3.
HOWEVER,,, if you have ducted air.. You will be fooling yourself as one room (The Fan only room) will not be receiving cold air. If you have non-ducted air, then go for it.
now: How to cool both ends with only 30 amps .....
I have a lovely fan here It is about a 10" box fan not at all unlike an Endless Breeze save for one thing.. The price.. As I recall it was 20 or 30 bucks, Runs on 12 volt with an adapter or lighter plug.. Got it at Flying-J or Pilot (Pilot in my case) remember to use your loyality card so you score points.
Looking for advice before your next adventure? Look no further.25,192 PostsLatest Activity: Apr 15, 2026
