JimK-NY
Dec 19, 2020Explorer II
As mentioned some CPAP machines are 12 volt and are much more efficient than those that require an inverter and 120 volts. There is also a big variation in power consumption for the humidifer module. Typically the humidifer will consume as much or more than the blower. Some CPAPs even come with heated tubing. I cannot imagine how much power that would take.
Getting accurate data on your specific unit can be difficult. Typically the Respironics manuals show maximum power needs. An efficient 12 v unit can use as little as 25 AH/night, maybe 50 with the humidify on a relatively low setting. Plan on draining a typical car sized battery to 50% or less every night or at most every 2 nights.
Looking for advice before your next adventure? Look no further.25,208 PostsLatest Activity: Aug 27, 2026
