RambleOnNW
Dec 20, 2020Explorer II
Bumpyroad wrote:RambleOnNW wrote:
With the CPAP I have the humidifier half can be unhooked and the hose connected to the back output that formerly connected to the humidifier. I bought a 12 volt adapter cable and I run that off a dedicated 65 Ah AGM battery. Without the humidifier the power consumption is low and I can run 5 nights no problem without recharging. Could probably stretch it to 7 if needed.
I found wetting the nose piece helps with the lack of humidifier.
Have dry camped about 25 nights this season with this setup.
you might be able to just leave the two connected and dial the humidifier down to off. it will then just work as a passover unit?
bumpy
Doc wouldn’t enable the ability to shutoff the humidifier, said split it apart instead.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 18, 2026
