ktmrfs
Dec 20, 2020Explorer III
a hint for humidifer. on many units you can turn off the humidifier but leave the water chamber attached. so..... fill the water chamber with warm/hot water before going to bed and turn off the humidifier heat. you will still get some humidification from airflow over the water chamber.
And my CPAP has an optional insulating wrap for the hose, using that helps when the hose heat is not used and reduces power draw when the hose heat is used.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 18, 2026
