- mowermechExplorerWe both are on CPAP. When dry camping in the motorhome, we run the machines on 12VDC. The two T-105 house batteries will run both machines overnight with no problems. We don't mess with shutting down the humidifiers.
During the day, I run the generator long enough to recharge the batteries, run the AC, use the microwave, etc.
It works for us. - BumpyroadExplorer
RambleOnNW wrote:
With the CPAP I have the humidifier half can be unhooked and the hose connected to the back output that formerly connected to the humidifier. I bought a 12 volt adapter cable and I run that off a dedicated 65 Ah AGM battery. Without the humidifier the power consumption is low and I can run 5 nights no problem without recharging. Could probably stretch it to 7 if needed.
I found wetting the nose piece helps with the lack of humidifier.
Have dry camped about 25 nights this season with this setup.
you might be able to just leave the two connected and dial the humidifier down to off. it will then just work as a passover unit?
bumpy - RambleOnNWExplorer IIWith the CPAP I have the humidifier half can be unhooked and the hose connected to the back output that formerly connected to the humidifier. I bought a 12 volt adapter cable and I run that off a dedicated 65 Ah AGM battery. Without the humidifier the power consumption is low and I can run 5 nights no problem without recharging. Could probably stretch it to 7 if needed.
Have dry camped about 25 nights this season with this setup. - ktmrfsExplorer III
JimK-NY wrote:
As mentioned some CPAP machines are 12 volt and are much more efficient than those that require an inverter and 120 volts. There is also a big variation in power consumption for the humidifer module. Typically the humidifer will consume as much or more than the blower. Some CPAPs even come with heated tubing. I cannot imagine how much power that would take.
Getting accurate data on your specific unit can be difficult. Typically the Respironics manuals show maximum power needs. An efficient 12 v unit can use as little as 25 AH/night, maybe 50 with the humidify on a relatively low setting. Plan on draining a typical car sized battery to 50% or less every night or at most every 2 nights.
my resmed unit if I turn off the humidifer and tube heater and run it from 12V draws less than 1A DC. 6-8AH/night. Now turn on the humidifer, another story, easily hit 25-30AH in one night. - ktmrfsExplorer III
Bumpyroad wrote:
don't run the humidifier (or get a passover type) and don't use the heated hose and it will run a long time.
bumpy
x2. and virtually all CPAP/BiPAP machines sold in the U.S. today run on either 12V or 24V ALL the time. the wall cord either has a converter built in, or there is a internal 120VAC to DC converter. So..... there is in virtually all cases an DC input as well. Most will run directly on 12V, many resmed units run on 24VDC. In either case the mfg or aftermarket sell adapters for 12V to run the unit. Resmed adapters are a 12v-24V converter.
so..... if you have a 12V cig lighter port in the trailer your set.
Also there are lithium battery packs for CPAP units that will run most units for 2 nights as long as the humidifier and tube heater are off. One night otherwise. - BobboExplorer IIII bought my manufacturer's 12v power cord and ran the 12v outlet to my bedside that Airstream couldn't be bothered to run.
- OasisbobExplorerOne of my fishin buddies uses a CPAP. I tried using one group 27 battery and ran the CPAP through a power inverter. It ran 5 hours until the low voltage alarm sounded. Next trip I bought a DC adaptor which plugged right into his CPAP. This ran through the night. Third trip out we plugged the CPAP directly into a D.C. outlet of my camper which uses twin group 27 deep cycle batteries and ran for two nights along with TV, furnace and lights. If you want details send me a PM. happy to help
- chiefneonExplorerHowdy!
I wired a inverter in the bedroom directly to my batteries in our 5er.
“Happy Trails”
Chiefneon - Sjm9911ExplorerWhat they said. Battery on dc, solar to recharge. No humidifier. Some also take the portable pack like the jackery as a back up. I dont have a cpap. But what they said will work. A guy on another fourm is testing the jackery now with solar to see how long they can go with just a panel and that. If i remember ill post the results.
- DurbExplorerMy son uses a Jackery 1000 for his Dream Machine. It uses 6% of a full charge for one night. He also has the optional portable solar panel to charge it. He has a cigarette lighter type power cord that plugs right into the 12V Jackery port.
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: Dec 11, 2025
