dieseltruckdriv
May 11, 2021Explorer II
mr_andyj wrote:
No problem except in #3 just aim the exhaust out, not in.
Even your truck burns some of its exhaust again, it is called Exhaust Gas Recirculation, there is an EGR valve to take some exhaust and re-burn it, so no, this is not going to be a deal breaker....
CO is heavier than air, so will find its way to the ground, not so much your windows, which will likely be closed bc you are running your AC anyway. Campers are not airtight, so always a CO monitor is in order.
The farther your gen is from the camper the better.
IF the exhaust is literally blowing onto the camper then you might die, literally, so deflect it or aim it away.
I can't imagine the sound a cheapo construction generator will make in the metal cavity of a truck though.
I know I am nitpicking, but CO is slightly lighter than air, but close enough that they mix easily.
I calibrate our CO sensors at work, and I have tested my Kidde CO detector that is in the bedroom of our 5er. It has a readout that is surprisingly accurate. I trust mine because I have tested and verified that it works. Most people don't have that option.
That being said, I run my Honda 2000 under my slide, so I wouldn't have a problem running it in the bed of my pickup while hooked up either.
Looking for advice before your next adventure? Look no further.25,210 PostsLatest Activity: Aug 29, 2026
