DrewE
Oct 31, 2016Explorer III
mich800 wrote:slickest1 wrote:
All the vehicles I have had here in Canada have had DTRL's |They only come on half as bright as the low beam. The tail lights do not come on which I personally think they should be on as well.
My 2008 F250 was originally a export to Canada so it has the DRL. But at least for this one it is just the regular low beams that come on when the vehicle is put in gear. Not a lower powered light.
While I don't know about your specific truck, usually on vehicles where the headlight bulbs are used for DRLs it's the high beams that are used at reduced power/brightness (either by connecting a resistor in series or by having some sort of a PWM chopper circuit). Low beam headlights are designed with a horizontal cutoff above which little light is produced, so as to avoid getting light (glare) into the eyes of oncoming drivers. DRLs, of course, are intended primarily to have exactly the opposite effect: they need to be visible to oncoming drivers but don't need to illuminate the roadway.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 07, 2026
