Water-Bug
Jul 10, 2014Explorer II
ScottG wrote:Water-Bug wrote:
First thing to do is check the current draw of your AC. There should be a manufacturers tag giving the model number and electrical requirements. Second, the electric water heater is probably drawing nearly all the current availale, when it is heating water. Cycling between water heater and AC may be necessary to prevent overloading the circuit. Third, although most home wall sockets are wired to 20 amp breakers, the wall sockets themselves are only rated at 15 amps. True 20 amp sockets will usually have a pin that is verticle to and connected to the + . ( two parallel pins for + and neutral, with a round ground pin below and a pin verticle to the + pin.)
I used to think those outlets were better as well but during a conversation I had with a Litton rep I found out the internals of both 15 and 20 amp outlets are identical other than the shape. He went on to clarify that the 15's will carry current just as well as the 20's.
The internals may be the same for ONE manufacturer but maybe not all. The specs are the specs. Never exceed the spec'd current for the receptical.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 27, 2026
