azrving
Jan 12, 2015Explorer
Sorry cant help with a repair place but may I please just offer my opinion on this matter. I would seriouslyconsider a new furnace at that age the heat exchanger is probably rusted also. If the original supply piping is black pipe it could well be rusted too. I would consider replacing it with new hose purchased from a propane supplier. It's probably a gravity type heater, I have looked for them myself with no luck you will probably have to replace it with a fan type model which will then also use battery power to run the circuit board and fan. These newer heaters are much safer as they have built in safety switches
Looking for advice before your next adventure? Look no further.25,187 PostsLatest Activity: Mar 17, 2026
