RoyB
Oct 27, 2016Explorer III
I have helped do a couple of 48-inch side mounted tool boxes. I like them because of the small over hang area which is great for dressing up the interior cables and adding a vent hole using a sink drain.
google image
google image
Here are a few photos from the gilldawg79 install.
Perfect size height wise for four each GC2 6VDC batteries... Can add switches and meters etc if you like in the over hang area... The lever lock is alot harder to jimmy to gain entrance. I would also use round stove type bolts on the bottom of the tool box mounting frame with the locking nuts etc on the inside floor area of the tool box. Makes it very hard to grind off and steal your whole battery bank box...
If you only have two GC2 batteries in the bank then the other half can be used for storage of tools etc... I would place a somewhat sealed panel between the two areas so the battery fumes would not do some damage to your tool's surface areas...
The one draw back using this box is some trailers will not have enough room to allow you to open the tool box hinged lid. One of the beauties of the TORKLIFT boxes is their top slides off. Great idea for close quarters... Their boxes comes with optional solar panel as well that can keep your batteries topped off... Another neat idea...
Roy Ken
google image
google image
Roy Ken
Looking for advice before your next adventure? Look no further.25,194 PostsLatest Activity: Apr 29, 2026
