mike-s
Sep 13, 2018Explorer II
Boards alone are not enough - what are the axle weights - ~4K lbs? Unsupported, boards are just going to bend or break for the span it looks like you'll need. Play around with a "draw" program to visualize the angles and clearances and get a feel for what span you'll need.
A couple of 2x12's set on sandbags to provide support and fill the gap to the street. Or, if you want a bit lighter/easier to handle, cut some triangle shaped pieces to fill the gap and glue/screw it together.
Looking for advice before your next adventure? Look no further.25,203 PostsLatest Activity: Aug 06, 2026
