colliehauler
Sep 13, 2018Explorer III
mike-s wrote:You might be correct, just trying to point out different options then having to build a bridge every time a person wants to use the RV.colliehauler wrote:My statement was made based on the posted pictures.mike-s wrote:You could have the RV parking to the side on a different level then the aproach to the garage. You could even make it level where you could use the camper and frig.colliehauler wrote:That looks to be impossible, without lowering the garage or modifying the public curb and roadway (good luck with that). As stated in the OP, "Not sure if putting a culvert in there would fly with the county but I suspect not."
Does a person really want to have a major construction project whenever they want to use the RV? Personally I would redo the driveway and be done with it.
Looking at them, I don't see anything to support that what you say is possible. There's not enough room between the garage door and that retaining wall, and there's no image which shows the rest of the driveway or lot.
My drive is between two telephone poles (single width) and expands to three car drive. Made it difficult to back the 5th wheel in. I'm lucky that covered storage is only 60 a month here. Sounds prohibitly expensive where the OP is located.
Looking for advice before your next adventure? Look no further.25,203 PostsLatest Activity: Aug 06, 2026
