dodge_guy
Sep 14, 2018Explorer II
92GreenYJ wrote:
Hey all. So we just purchased our new 32 foot Sunseeker and upon getting it home discovered a bit of a problem. While I have plenty of space for it in the driveway, I can’t actually get it up into the driveway. The hitch guards scraped just a hair turning onto my street, but turning into the driveway was a huge can of worms. I got the RV about halfway in when I heard the guards start to scrape the asphalt in the street.
Me being me I decide to back it up and give it a bit more speed. Big mistake. I hit a point where the hitch guards dug into the sphalt so much that I couldn’t move either way. Tried putting some 2x4s in there. No joy. It was stuck good. So I hooked up a strap to my Hemi Ram 1500, tossed the wife in the drivers seat of the coach and yanked it out with the truck.
So for right now it’s parked on the street until I figure out what to do about this. I ordered a set of rollers to go on the bottom of the hitch but I’m not sure that’s gonna be enough.
Because the big dip at the bottom is right at the street I don’t think I could have the driveway leveled out at the bottom out into the street. Not sure if putting a culvert in there would fly with the county but I suspect not.
What have you guys done in this situation? Heavy duty ramp of some kind from driveway to street to raise it enough that the ass doesn’t drag?
Dump a yard of pea gravel at the bottom to build up the dip? (Again not sure this would be allowed)
Open to suggestions.
Here are a couple of pics of what I am dealing with.
I haven't seen it mentioned yet, but have you tried backing it in from where its parked at on the street? cut the wheel to the right and let one side go up first and then the other. my neighbor had a similar issue with his Class A. he had to back in at an angle to clear the driveway. It worked for him. It should work for you. I also see a curb next to the RR wheel. maybe put a 2X4 there and get that tire up over the curb first while backing in. I would think that would allow the rear to clear while backing in. You will never be able to pull in though!
Looking for advice before your next adventure? Look no further.25,203 PostsLatest Activity: Aug 06, 2026
