Grit_dog
Sep 17, 2018Trailblazer
92GreenYJ wrote:Hammerboy wrote:Grit dog wrote:
92YJ, unless I’m missing something, there’s no “low” spot to fill in. From the pics, your driveway goes up from the gutter line, correct?
You can’t re work the curb and gutter and street grade, you’d have to lower the driveway.
I don’t see a solution by filing anything in. But ICBW.
I think its doable. It looks like if he excavates that sharp bend on the drive about 6-8' from the street he will make it. My drive is much steeper and I make it fine. Just needs a more rolling surface with no sharp bends in the driveway
Dan
Take another look at the pictures of it in the driveway. Where that big stack of pavers goes out in a line is the low spot I am referring to and what ultimately stopped me getting it in there. The rear tires of the RV dropped into that low spot and that was what hung me up on the rear. By building that “bridge” out of pavers/ timber the rear stayed up high enough not to hit the road on the way in. So I think the ultimate solution is going to be to fill that low spot in and build it up as I did with the pavers, but this time do it permanently with concrete. That way I don’t have to spend 45 minutes building my bridge every time I want to take it out.
Don't ya love people's opinions about how you're affecting others lives......lol.
I see what you're saying about the grade break between the driveway apron coming off the curb, up to the first joint. Yes if you straight graded that, lowering it a bit, to the second joint it would help a bit with break over angle down at the curb, but I dont think it will help with the RV. Wheelbase too long. This was the other fellows suggestion.
If you're simply building up the little dip in the pavers inside the curb line, that could help and if it's enough to get the camper "over the hump" that's great.
But look at the pic of your truck with front wheels in the gutter line. There's not much you can do about that overall condition except to basically lower the whole driveway. Which isn't really feasible.
Looking for advice before your next adventure? Look no further.25,206 PostsLatest Activity: Aug 22, 2026
