ependydad's avatar
ependydad
RV Fire Exit (aka exiting Dukes of Hazzard style)
We were parked in a field tonight with no one around and were playing with the fire escape windows to get air into the camper. We have been talking for a while about emergency planning with the fire escapes and practicing exits and whatnot. So tonight, we played around with the idea and frankly, I'm very sad and very afraid.
#1- I could get my kids out *if* I'm standing outside and able to "catch" them.
#1a- we didn't test it but my wife could catch my 3 year old son, but no way would be able to catch my 12 year old daughter (not without getting hurt in the process; but I guess if it comes to that- being hurt or kid dying, the decision is easy).
#2- neither my wife or I could make it out. (yes, bold, underline, and caps.)
Maybe we'll be willing to plummet face first to the ground in the event of a real fire. BUT- in practice, neither of us could force ourselves to do it.
Now, for the videos. My apologies for fat guy stomach hanging out of the bottom of my shirt.
Daughter came out. But notice it took 20 seconds and that doesn't include the couple of stutter starts to figure out the best way.
https://youtu.be/5NG6GEiSdgo
Son popped right out, but this was the lowest window. Would he come out IF he had to free fall a bit before I caught him?
https://youtu.be/FqBkp41R36w
And now, my 3 failed attempts. I gave up fairly quick because that was an option. But still- the idea of falling face first down 6' wasn't comfortable.
https://youtu.be/f5sv1WDEzeQ
https://youtu.be/KlZ0QCNkr2A
https://youtu.be/gKmmaVSSK2o
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    I have had my door latch break twice (the current striker bolt is of superior metal and won't break... I hope) and had to use the Emergency windows.. No problem at all for my 65 year old by 320 pound frame.. Nice short drop to the ground (a foot or less) when I release the window ledge.. Getting back in however takes a ladder.
  • Never underestimate your ability to ESCAPE in a life/death situation. Never underestimate your ability to risk danger for the sake of saving your family. I understand the desire to learn your escape routes and practice, but in the heat of the moment (no pun intended), you will be out of that unit one way or another.
    Head first is the way to do it f you have to exit through a port hole. Your gut compresses easier on the bottom. If your gut condenses upward, there's too much body mass up top and you might get stuck. FWIW, I have a business colleague that's about the size of the OP and he goes in and out of 14" and 16" oval shaped port holes on tanks. It's a slow process, but it can be done. The one time he tried to come out feet first, he got stuck and almost passed out due to the fumes.
  • Feet first: Sounds good but a rather awkward thing to do. As others have said, a fire licking at your heels is a good motivator but only after trying to get out the door.
    Fire extinguishers: The factory supplied ones are fine. You need to take them out every few months and rotate them. If you can't feel the material inside moving a few raps with a piece of wood on the bottom will usually break the contents free. Only if you can't get the material to move do they need to be changed.
  • My fire plan:
    1. I threw out THE rinky dink fire extinguisher that comes with RV's.
    Replaced it with "3" standard house extinguishers. One up front, one mid ship, and one in the bedroom.
    2. They make many different models of "fire escape ladders" that affix under the window in your RV that is your fire exit window. IMHO a must have.
    3. I have seen MANY Class A, and big bus coaches where when parked the owners place one of those foldable ladders under the fire exit windows. Being proactive does save lives.
    A real must for the elderly RV'er who may have limited mobility or even us younger ones that would have a real hard time making it out and down onto the ground without killing ourselves too.
    AND BTW:
    I was at an RV rally where the fire department was putting on an RV fire safety class.
    The fire department is very concerned about the extinguishers that come with RV's they showed us that The small fire extinguisher that comes with RV's. They ALL settle to the bottom, so when you go to use them in an emergency they do NOT work.
    They also stated that majority of the RV fires they where called out on, it was BECAUSE when the owners went to use the factory provided extinguisher to put out a small fire.......only to find it had settled to the bottom and did NOT work.
    That night a few of us decided to try our 'factory' supplied extinguishers frighteningly none of them worked. The key here is the longer you have your RV the more apt it will have settled firmly to the bottom. :(
  • Isn't the idea to go feet first, on your belly, so you can hinge at the waist and lower yourself down? I'm a bigger dude too, but when it comes to getting out quickly, efficiently, and safely it seems to me to let my gut drag and get scraped up than try to dive bomb head first. You were trying to avoid damaging the RV, which I appreciate, but if there's not a dinette or something there to start on your belly and push yourself out with your hands then get your behind on the edge and roll so your belly is on the window frame and your legs are dropping to the ground. Slow yourself as much as possible with your arms and upper body (via friction if you have to).
  • I do believe that Old-Biscuit and fortunately have never been faced with the beast.
    It does give me a marked reason for getting proper fire extinguishers, training on their use, and properly placing them around the rig. Including trainings for my wife and older kid. As well as my mother-in-law who watches the kids overnight in the camper for us from time to time.
    I'd also like to figure out a way to actually be able to make it out, or at least have a viable way to get to the ground. Face first seemed like it would suck and I couldn't figure out feet first.
  • Practice vs FOR REAL.....
    Fire is a motivator and if necessary you will throw love ones out and dive afterwards.
    Fire is a motivator.
    I express this as one who has fought fires in confined spaces (Engine room NAVY, Fuel Oil Tank NAVY and several in Power Plants during my career)
    You will do what is necessary IF needed. Practice is good and helps ID issues/concerns.
    Have a plan-----Know what to do, how to do it and WHERE to meet up.
    Remember 'escape windows' are Option B & C.........Option A is out the entry door ASAP
    Fire IS a motivator!
